Hello, i have a problem.
I have downloaded bluray film and there is audio: LPCM 5.1 / 48KHz / 4608 кб/с / 16-bit
So i need to convert lpcm to dts or ac3, but i dont know how??
Could you please help?
p.s the film duration is about 2hours, but then i extract that audio from m2ts with tsmuxer i get audio track duration just about 1h.
Thanks, for answering, and helping![]()
Results 1 to 10 of 10
Try running the files through Clown_BD (free), and set audio output to AC3, at a bitrate of 448 or 640 kbps. Java must be installed on your computer. Just point Clown_BD at the folder. Pay attention to settings/options at each step. I presume you want Blu-Ray output, don't forget to set that.
Forget converting to DTS, you can't do it for free and it offers no advantage over AC3.
Welcome to the forum.
[EDIT] It's not unusual for tsMuxer to crap out on audio, but usually it's DTS-MA or True-HD that causes problems.Last edited by fritzi93; 2nd Dec 2010 at 17:53.
Pull! Bang! Darn! -
clow_BD deosnt work for me :/
Say that commercial soft if you know
p.s thanks, for welcome ^^ -
@bigman
Hi,try multiavchd[free] or bd demuxer pro[not free].
Wait...I remember I had once this problem,solved the probl. by using ConvertXtodvd[not free] obtained a dvd with ac3 sound...after that I extracted the sound from the new created dvd...
Happy encoding/decoding/demuxing,
M
LPCM to DTS
By Benjy in forum AudioReplies: 8Last Post: 25th Jun 2010, 06:53 -
Converting LPCM , DTS and AC3
By Benjy in forum AudioReplies: 10Last Post: 8th May 2010, 06:20 -
DTS-HD/MA to LPCM
By scub in forum Video ConversionReplies: 0Last Post: 27th Apr 2010, 18:39 -
DTS-HD to LPCM and PS3 - How I Did It
By decker12 in forum Blu-ray RippingReplies: 11Last Post: 25th Aug 2009, 19:04 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 09:09
