I own a sony dvd player and I would like to play pal dvd's from Europe. Can I convert my existing dvd player to allow pal playing.
	You don't convert a dvd player to play pal, either it does or it does not.
 The problem is usually the region coding of the disc, either make a backup of the disc that is region free (region set to all) or find a hack to make your player region free.
 Then hope your $sony will convert PAL to NTSC.
 But as hech54 stated, $ony, neither one.
 On the optimistic side of things, you have maybe a .01% of it being done and a 99.9% chance it can't be done, although i have never heard of it being done.
	If the original poster lives in North America, I am not aware of any Sony players currently sold in that area that can be unlocked for multi-region play. In the past Sony did sometimes support PAL playback even if the player could not be unlocked so you could try ripping a PAL DVD from another region and burning a region free copy as that might play. But that's not really much of a solution. By the way, the situation is equally grim for Samsung players sold in North America.
	If it's not a large number of DVD's, how about converting the PAL to NTSC?
	Play it from your computer Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  DVD players that play PAL & NTSC - do you need a PAL television?By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53
  To convert or not to convert a pal dvdBy nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35
  my panasonic standalone dvd can't play pal dvds...but can play pal svcd'sBy stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46
  How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
  convert PAL HDTV 1080i -> PAL DVD 576iBy halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
