i dont recall if this happen before, using xp (os) .now im using windows 7(64bit),and i'm using avs video convertor(before i was using a free tool,not sure about the name)but still here having this chop off screens on the both sides,left and right,the height is ok..i tried so many ways to fix this...when i take the video to my car,the image of the video is reduce like to be playing in 4:3 tv aspect................the only player tha show me full screen is bs player(in the pc),but windows media,gom,winamp...etc............same problem...if anybody could help me...........for my car i need to use.....no more than 2000(bitrate),frame size720-480..........otherwise it wont be played.![]()
Please give more info about the video. What resolution/frame size? Video codec and container?
I would use xmedia recode, it can easily crop under the crop/preview and convert to whatever format you like. -
ok mostly the files(originalS) are high definition,music videos.......(1280p.)now i have been using avi(format)and, i guess the container is (dvix\xvid)..and i tried to do it with mkv(mpeg4-dvix\xvid).........with the mpeg(mpeg2),it seems working ok.but the video quality isnt good....well not crispy and sharp as the others,plus the file size,seems to be smaller in avi(dvix\xvid)my intention is to reduce the bit rate and resize the frame size to 720-480..........otherwise it wont play in my car....(it doesnt support more than that)it plays through a usb memory..........................ah....the other free tool was super....really good ...but it started to act this way as avs video converter.................................................. .....................................
hi ,baldrick....just to thank you for the advise of using the mentioned tool..it worked.....eventhough avs convertor has a better interface and looks more solid software,but some how is pissing me off a lot...........it took me abit while to set things right...but the only thing i dont see here is how to get a batch setting...in case i wanna load a punch of files in xmedia recode.......i would appreciate some help if you can.............thanks again for the help.................
AVS4You Video Convertor
By didikai in forum Video ConversionReplies: 4Last Post: 24th Sep 2012, 15:33 -
Freemake Video Convertor. What a tease.
By hellfire45 in forum Video ConversionReplies: 8Last Post: 28th Aug 2011, 19:58 -
how do i take avs logo off avs video
By tnwolf35 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2010, 22:08 -
Avs video convertor
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 16:25 -
FLV Video Convertor
By snuggels in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2007, 01:41
