Hey all,
Here's my problem. I have a wmv from which I would like to cut a part out and I have been searching the net for a simple solution without reencode. I downloaded asfbin & cut assistant to do just that. Now I have tried to "crop" the section I need but the resulting file is a 2 seconds crop from another part of the movie and I have absolutely no clue why it would do that because I set the start & end times of my section precisely to the frames I want, about 10 times already and it always does the same. This is getting nerve wracking.
I am not a specialist at all with this stuff, I would just like to cut my damn video, so if anybody would be so kind as to help me on my problem or guide me through the process as I obviously did something wrong which I'm totally oblivious to, that would be great!
I downloaded asfbin & cut assistant from the link in here, I set up asfbin.exe in options>settings in cut assistant, I put the -rkf. That's all I did.
Thanks in advance!
EDIT: ok after some digging I seem to get that error: "Decompression error: VCM decoding driver is not available", I can't seem to find that VCM thing on the web though...
OK, so I finally got rid of the error message by installing the VCM and every codec mentioned during the processing are now supported.
Problem is, I now get an output video which is the right frame size, the right length but all black and it doesn't play.
Here's the log:
Code:C:\Users\XXXX\Downloads>asfbin -i "0155_18M_1840.wmv" -o "C:\ Users\XXXX\Downloads\0155_18M_1840.cut.wmv" -start 1:55:53.6 28 -duration 0:23:24.751 -rkf ASFBIN - version asfbin 1.7.13.756. Copyright 2001-2009 by RadioActive. Non-commercial version. Visit www.radioactivepages.com for latest updates. Checking VCM Drivers: FourCC MPG4 is supported [driver=mpg4c32.dll] FourCC MP42 is supported [driver=mpg4c32.dll] FourCC MP43 is supported [driver=mpg4c32.dll] FourCC WMV3 is supported [driver=wmv9vcm.dll] Extending support for additional video formats: Input file list: File no. 01: C:\Users\XXXX\Downloads\0155_18M_1840.wmv exists Segments to copy: Segment no. 01: start = 01:55:53.628, duration = 00:23:24.751, Overwrite file C:\Users\XXXX\Downloads\0155_18M_1840.cut.wmv? [y /n]:y Parsing file C:\Users\XXXX\Downloads\0155_18M_1840.wmv: 0-100%:.....10.....20.....30.....40.....50.....60.....70.....80.....90.....100 Stream [1]: Audio Media, Bitrate = 64032 bits/s Stream [2]: Video Media, Bitrate = 1250000 bits/s Writing output file C:\Users\XXXX\Downloads\0155_18M_1840.cut.wm v: First samples will be recompressed if non-KF (key frame). 0-100%:.....10.....20.....30.....40.....50.....60.....70.....80.....90.....100 Indexing output file: 0-100%:.....10.....20.....30.....40.....50.....60.....70.....80.....90.....100 C:\Users\XXXX\Downloads>
Since there is no error message I don't think I can go any further than that by myself, any help would be appreciated! By the way I'm on windows 7 if it's any help at all. -
I don't use Cut Assist, so I can't help you there; but since your source is a WMV file, why not just use Windows Movie Maker?
Using Mencoder to Cut Commercials from TS/TP fils not working
By Randall_C in forum Video ConversionReplies: 0Last Post: 3rd Jul 2010, 16:47 -
automatic or batch processing in Cut Assistant: possible?
By cbarduck in forum EditingReplies: 0Last Post: 9th Feb 2009, 06:11 -
Final Cut HD templates are not working.
By Tom in HD in forum MacReplies: 7Last Post: 30th Sep 2008, 21:33 -
How can I associate cut assistant with virtualdubmod
By pondleaping in forum EditingReplies: 3Last Post: 2nd Aug 2007, 09:06 -
two problems with virtualdub1.71 and its cut assistant
By pondleaping in forum EditingReplies: 7Last Post: 7th Jul 2007, 12:42
