  1. I found a link but I have no tried the drivers on the website. I was wondering if the drivers on http://btwincap.sourceforge.net/ work for WinTV Go cards. If so should I get them or are the Hauppage ones better?
  2. Banned
    Jun 2001
    UK
    Hi
    well if I was you If your drivers are working from Hauppage, I would leave them alone. I did try the capture program and it crashed my system... I have a standard Hauppage WinTV
    It tooks some doing, but it did display the TV, then crashed and re-started the computer (While I was encoding)
