Hi all,
I got a copy from my friend of the Avatar untouched bluray extended version which contains these two folders BDMV & Certificate folders in the root Avatar folder. I tried to burn using IMGBurn and it suggested me the correct format to burn and finally I mounted the image using VirtualCloneDrive in my PC. When trying to play using PowerDVD10, I get an error message saying "Format in disc not supported".
My friend told me that this copy is the complete original disc which includes the menus, extras, audio options etc.
Can you please guide with the correct method to burn this bluray structure back to the original disc so that I can view it as the original disc which shows the menus features and other options etc.
Thanks in advance.
Closed Thread
Bluray file structure - art & info files?
By enzothebaker in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Mar 2012, 16:23 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 11:29 -
bluray iso back to bluray format
By mysts in forum Blu-ray RippingReplies: 3Last Post: 4th Jan 2011, 14:42 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05
