Ok need some opinions. I will have this drive soon and i was wondering about my setup. I have the Alienware Aurora ALX. Current set up, Windows 7 64 bit on a WD 300 GB 10k velociraptor. The others are 2 Blue caviar 500GB and a 2nd 300GB 10k velociraptor. Do you think it's best if i switch for my main OS system to the 600GB raptor for better speed on Windows 7, or leave as is, I do alot of video editing which is why i bought the raptors. When the Solid States become cheaper than i will switch to one of those for the OS system. Appreciate the thoughts anyone. Thanks
Results 1 to 9 of 9
What kind of video editing? Uncompressed SD?
A fast C:\ drive isn't going to speed editing.
Per Electronics Mag
Sustained data-transfer rate varies from 125 MB/sec at the outer cylinders to about 80 MB/sec on the innermost cylinders. Burst data rate is around 240 MB/sec.Last edited by edDV; 1st Dec 2010 at 15:50.
http://www.kiva.org/about -
OK, ripping goes at a modest transfer rate. I see no need for the Raptors.
Thanks for the quick response, so disregarding the ripping, since i'm getting this raptor as a gift, what about system boot time or loading programs, do you think the 600GB raptor will be faster than the 300GB raptor, again thanks for the help.
WD claims new generation is 15% faster than previous generation.
Newer Raptors are faster than older ones, else why bring them out?
The electronic components of the power part adopted a lot of Rubycons.
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 17:18 -
Video Archiving using Mp4 - MKV on a Western Digital storage drive
By ejai in forum DVD RippingReplies: 23Last Post: 9th Sep 2009, 22:50 -
Western digital external hard drive 160 gig
By pantangs in forum ComputerReplies: 2Last Post: 15th Jun 2009, 16:33 -
400GB External USB Hard Drive - Western Digital Elements $49.95 AR Staples
By edDV in forum ComputerReplies: 40Last Post: 5th Dec 2008, 17:53 -
Western Digital Portable Hard Drive question..
By Soccerman77 in forum ComputerReplies: 1Last Post: 9th Feb 2008, 02:29
