What is the best (easiest) way to reduce a DVD movie so it can fit onto a DVD-R???Example, a move that is 4.7GB in size and I want to edit parts out of it so it will fit.
first off a movie thats 4.7g doesn't need to be reduced (it should fit just fine) second off you could try using a vbr to reduce size without cutting. I don't think there is a best way to edit a movie so that it'll fit. But there are several software's to do editing, i like premiere some ppl prefer ulead media studio or some such....
ifoedit ... strip out an extra audio stream or subtitles ... that will normly shave off a few 100 MB's .... a bit more work if your orginal dvd is 5G +
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Cutting an existing DVD
By stumpman13 in forum Newbie / General discussionsReplies: 7Last Post: 6th Aug 2009, 10:49 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 02:18 -
Cutting a short clip from a DVD
By Nutmeg7 in forum MacReplies: 1Last Post: 13th Nov 2007, 22:58 -
Cutting scenes from dvd using Nero
By aelfheah in forum Authoring (DVD)Replies: 0Last Post: 16th Jul 2007, 12:57
