Read my blog here.
Edit in AVI Demux. Save the title. Open the title in VLC. Click on Tools -> Media Information. Clear the Artist field. Save Metatdata.
I have tested this and it works with current versions of both tools.
However if you make any further changes in AVI Demux, you will have to clear the metadata again. Any time you save out from AVI Demux, you will have to clear the field in VLC and save it again.Read my blog here.
Sorry for the late response, was busy with other stuff....
But the method given, really does not work on my comp -
Hello Pitorasilo,
As a user of VLC media player I stumbled on the same problem as you did:
VLC shows "Avidemux" for the video title if it has been remuxed with that tool.
I have found a simple solution to remove that entry and VLC will just show
the name of the video file (as without metadata).
1. Open the video file in an hex editor like HxD or a utility like Ultra Edit.
HxD and Ultra Edit create automatic backups...
2. Below you see the lines that contain the term Avidemux.
It only occurs once in a Avidemux video file...
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00000110 00 00 00 00 00 00 00 00 00 00 15 49 A9 66 01 00 ...........I©f..
00000120 00 00 00 00 00 4C 2A D7 B1 83 0F 42 40 7B A9 88 .....L*×±ƒ.B@{©ˆ
00000130 41 76 69 64 65 6D 75 78 4D 80 8B 4C 61 76 66 35 AvidemuxM€‹Lavf5
3. On the hex side overwrite the enry © (hex A9) with a space (hex 20) so you will end up with:
00000120 00 00 00 00 00 4C 2A D7 B1 83 0F 42 40 7B 20 88 .....L*×±ƒ.B@{ ˆ
4. Save the file
It takes one to two minutes to resave, depending on the file size.
Done.
No remuxing and all that, just editing.
Just be careful what you overwrite... only the entry shown above!
Hope this helps.
Greetings,
Halfsoft.Last edited by Halfsoft; 24th Aug 2011 at 19:21. Reason: Firts version also removes time index and thumbnail
I figured this out, for me, anyway. I was having the same problem. I was able to use VLC to change the metadata on mp4's, but not on mkv's or m4v's. So, I tried using avidemux to convert my mkv's/m4v's to mp4's, and 1) it was just a container conversion, not a transcode, so it was fast and did not degrade the video, and 2) the resultant mp4's already had the filename saved as the metadata title, so I didn't even need to use VLC as a follow-up.
avidemux seems to work well with mp4 but not with mkv / matroska on linux. Note, if you use some of the subtitling or multi-track audio features of mkv, this may not work out perfectly. I'm not sure.Last edited by gregconquest; 5th Aug 2013 at 01:57. Reason: clarified using avidemux for container conversion
AviDemux file title embedded in video
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2010, 05:41 -
Can you change Aspect Ratio in Avidemux without reencoding?
By tokintmash in forum EditingReplies: 3Last Post: 13th Aug 2009, 09:05 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 16:30 -
is there a choise? change title in automkv
By caner12 in forum Video ConversionReplies: 1Last Post: 9th Feb 2009, 04:23 -
aspect ratio change and Avidemux
By Ogilvy in forum LinuxReplies: 0Last Post: 30th Apr 2008, 09:44
