Happy Holidays Gents,
For the 1st time I've decided to and been put into a position to hopefully record Christmas TV specials to tape on the A1 at high quality . My TV is nothing fancy but hopefully adequate equipped as it's a 32" Sony Bravia.
Sorry for my ignorance and perhaps before all of this is through I will need to buy some additional connectors and cables to get the optimal signal flow into the A1 to the extent achievable.
I know how to project an image to an to HDTV easily enough, it's the set-up to record a signal from HDTV direct to tape that I need suggestions for please.
Would at least one of you be willing to walk me through it and if there are multiple solutions my ears are certainly wide open. Any of you Sony Bravia owners?
I do not have a tv capture card or a TIVO.
Thanks so much.
don't think you can. the cam accepts DV, HDV and SD composite for input video afaik. check the manual to verify.
The XH-A1 does not record HD video from a TV or any other device.
Methods to capture HD include
1. ATSC tuner card for PC or Mac
2. MPeg2-TS capture off cable box IEEE-1394 port
3. Record off stand alone ATSC tuner with HD capture device.
Most HDTV sets lack video output connectors and those that do only output SD.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Looking for hardware to record HDTV brodcast (Rabbit ears)
By stealthblue in forum DVB / IPTVReplies: 20Last Post: 14th May 2011, 23:20 -
Wanting to record/playback over the air hdtv...please help
By jnaarnold in forum DVB / IPTVReplies: 6Last Post: 16th Jan 2009, 22:57 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12 -
The best card to watch/record HDTV?
By Chuck_Johnson in forum DVB / IPTVReplies: 31Last Post: 9th Feb 2008, 12:05 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
