I would like to know why I have to wait about 10 seconds before the video is starting to play? It concerns "FLV" video file format. There is a message "Opening..." on status bar. Is there any way to fix it?
Thanks!
PS. I haven't this problem for instance with VLC.
	I already have had ffdshow with K-Lite Codec Pack.
 > "- enable flv in ffdshow."
 I'm not sure what you mean: Codecs, Format -> FLV1, Decoder -> libavcodec. Is this it? (I can't see FLV only FLV1)
 It do not work but thank you for your interest and help. You inspired me to look on "Internal Filters".
 I marked the FLV option in "Source Filters" list and the problem was fixed... but VLC is still fraction of a second faster
 Best regards
	The long pause happens with some combinations of source filters and codecs. From MPCHC try going to View -> Options -> Internal Filters -> Source Filters and changing the state of the FLV reader.
 If that doesn't help change the state of the Transform filter used to play that FLV file (ie, figure out what codec is used in the file and change the state of that filter).
  MPC and MPC-HTPC Video SizingBy ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 11:52
  mpc-hc won't play certain vids mpc will?By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41
  Problem with MPCBy crossmr in forum Software PlayingReplies: 0Last Post: 17th Aug 2009, 23:36
  Streaming MPC ProblemBy neumannu47 in forum AudioReplies: 0Last Post: 26th Oct 2008, 17:57
  MPC playback problemBy ecc in forum Software PlayingReplies: 1Last Post: 14th Jun 2007, 12:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
