I still can't open AVI files.I have read some threads that I have to create script file with for example Notepad with avs extension and the same name"Video"but without success(what inside text file???).
I have AVI files in separate folder called Video .What is the next step for success?
Regards.QUALITY HAS A NAME -
I see what you're saying - I assumed you were familiar with basic Avisynth.
easiest way to see what is going on is to use AVStoDVD. It''s a great front end to HCenc and QUenc,
and much more. You can see the Avisynth script used in the edit title/avisynth tab.
Basically, a simple script like this is all you need:
Video = DirectShowSource("I:\path\myfile.avi", fps=29.97, audio=false)
Video = Video.ConvertToYV12
Video = Video.AddBorders(10,0,10,0)
Video = Video.Lanczos4Resize(720,480)
return video
The AddBorders corrects the aspect ratio so that the resize produces the proper shape picture.
AVStoDVD calculates all this for you.
AVI files won't open in Avidemux
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 18th Mar 2025, 14:22 -
Adobe Premiere - MainConcept's H.264 vs x264 open source encoder
By rallymax in forum EditingReplies: 159Last Post: 19th Jun 2012, 19:51 -
How to open MP4,MKV,WMV,RM,MOV,OGM with any editor,encoder
By Baldrick in forum User guidesReplies: 78Last Post: 24th Feb 2011, 09:53 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 10:36
