Mabuhay!
I've been using AutoGK 2.40. I have observed that only 1 file can be loaded at a time in the Input File field. Accordingly, it is advisable to include IFO together with .VOB files in converting to .AVI to have the complete information particularly the sound. As my first time experience with AutoGK converting .VOB to .AVI, there was no sound output in the converted file. Your ideas are highly appreciated.
I am what I am. So what? -
Decrypt just the title you need/want and not the entire DVD, and then load either the IFO or the VOB.
If the VOBs are numbered sequentially and you load the first one, the rest get loaded automatically. So, your statement is incorrect.I have observed that only 1 file can be loaded at a time in the Input File field.
And upgrade to v. 2.55. -
@manomo thanks for your suggestion. i will try to do it.
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 06:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 02:26 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 14:07 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
