Results 1 to 11 of 11
    Jun 2005
    Vermont
    I have the new Philips & am trying to play videos from a WD Passport 500GB external HD plugged into the USB port. It won't recognize the drive...in fact I also have a Seagate Freedom 320GB drive & it won't recognize that either. Now here's the interesting part. I have a friend with the same identical Philips (same model) and they both play fine in his. Any idea what gives? And would a powered USB hub solve the problem? Any ideas?
    It may only support FAT32 partitions.
  3. try a thumb drive just to be sure u have no issues with the USB on the DVD player (defect)
  4. Banned
    Freedonia
    A powered enclosure for the drives or a powered hub might fix the problem, assuming that they aren't NTFS formatted. But I can't give you a 100% guarantee. All I can tell you is that we have had reports in the past of some external drives not working on Philips DVD players until the drive became powered either by a hub or its own enclosure.
    Jan 2010
    How strange - I have the exact same problem today. Just got the player in and tried to hook both the WD 500gb and a Seagate 1tb up to no avail. USB flash works fine.
    What's another good player out there supporting external hard drives?
  6. WD Live (no dvd player)
    LG BD530.BD,MKV,Divx/HD,, with USB 2.0 $69 from amazon.com(check the review by DM)
    or your local wal-mart if they have any left $65
    http://www.amazon.com/gp/product/B00400NL02/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
    pix of my WD passport 250 connected to the LG 530 (vob)
    Jun 2005
    Vermont
    I guess I forgot to mention that I did format both the WD 500GB & the Seagate 320GB in FAT32 & loaded them with AVI format movies. Also it does play the AVI's just fine from a thumbdrive (3 different ones) and as I also did mention that those 2 hardrives do play in another DVP3560 that I tried them on. Too bad I just got the Philips as I did not realize that the LG was available & would also do what I wanted. Just can't justify getting another player right now. Any ideas on a reasonably priced powered USB hub that might work?
    Jan 2010
    I had read reviews that said the Philips would play from a external hard drive so I'm disappointed as well. I'll take the DVP back to Wal-Mart and pay the 30 bucks more for the LG but it would be nice if I could get the Philips to work!
  9. I own the Phlips 5990 model it doesnt have any issues with external hard drive.
    maybe it's firmware issue/defect USB on the player
    Jan 2010
    Maybe its just the 3560?
    The USB works fine with flash drive, just not hard drive.
    DIdn't think about updating the firmware - you think that would
    ork?
    Jul 2001
    The feature list mentions flash drives specifically and other USB devices only in general, that is - it doesn't come out and say hard drives are supported. The user manual only has:
    USB
    - Compatibilty: Hi-Speed USB (2.0)
    - Class support: UMS (USB Mass Storage Class
    The latest firmware can be found here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP3560/F7&scy=us&slg=en
    Perhaps they've added HD support.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
