  1. Hi there !
    I'm trying to install ffmpegX on my iMac running Os X.6 as stated in the topic's name.
    Here's the message I get :
    ##sh: -c: line 0: unexpected EOF while looking for matching '"
    sh: -c: line 1: syntax error: unexpected end of line
ID:	4458 Click image for larger version
    Don't find something close to this in the forum ... any idea?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    This error is usually a symptom of an apostrophe character where it isn't expected. The interpreter tries to interpret it as the start of something in quotes.
    This could be such a character in a filename (John's Letter), folder name (Kate's notes) or volume name (Pete's Disk). But here, I suspect you have an apostrophe character in your password, as has been an issue before on this forum (1) (2) (3) (4).
    Try after changing your user account password (temporarily) to a password with just alphanumeric characters.
  3. arf didn't see those topics before ...
    You suspect right ! I'll try without !
    ----- EDIT ----
    It works ! Thanks
    Dec 2010
    Thailand
    is there a ffmepgX version for OSX 10.6 (without having to install Rosetta)?
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    When creating a Universal Binary of ffmpegX, the developer erroneously let a PPC version of gnutar slip into the application package. This only affects new installs on 10.6, as gnutar is only called upon at installation time.
    One possible workaround for this is to replace this gnutar inside the application package with a copy of the Intel version of gnutar that came with the OS.
    /Applications/ffmpegX.app/Contents/Resources/gnutar
    /usr/bin/gnutar
    Dec 2010
    Thailand
    Thank you very much for your explanation and hints;
    have a nice holiday!
