All the subs except the two first English ones are missing the "language flag". In MPCHC/VLC/XBMC it'll just say "Undetermined/Unknown" but still work. Is there anyway to fix this or change some setting so they are properly named?
Here's how it looks in Blurip:
These are the four first subs after the remux is done:
Code:Text #1 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English Text #2 ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English Text #3 ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Text #4 ID : 6 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Text #5 ID : 7 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
  Can not extract PGS stream from MKV fileBy gonzalu in forum SubtitleReplies: 27Last Post: 19th Aug 2016, 04:48
  MKV with .sup(PSG) subtitles to m2tsBy captforest in forum Video ConversionReplies: 6Last Post: 19th Dec 2014, 17:11
  Playing PGS subtitles with MPC.By doctorm in forum SubtitleReplies: 2Last Post: 28th Jan 2012, 13:25
  Remuxed mkv using mkvtoolnix leaves file unplayableBy micnolmad in forum Video ConversionReplies: 4Last Post: 10th Jul 2010, 12:33
  Demuxing PGS SubtitlesBy ematthys in forum SubtitleReplies: 2Last Post: 11th Dec 2009, 14:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
