hi i have a samsung tv and it plays via USB .mkv coded H264, level @4.1.
the problem is that i have some files level @5.1
i read your forum and i find a way to convert it to 4.1 : extract video file with mkvmerge (take minutes) and convert it to 4.1 with h264info. but it take many hours/days. i just have a amd 3200+.
so. is there a way to make it in minutes or at least an hour? just to leave everything intact and convert from @5.1 to @4.1.
can mkvmerge do that when remuxing via comandline or something .ini files?
thanks.
	you can do it with this special ffmpeg build
 http://forum.doom9.org/showthread.php?t=152419
	yes. everything was ok. thanks.
 also, someone told me about IDC Multi Changer. Tried it and it works too. converted from 5.1 to 4.1. It make the change instantly. even if mkvinfo report file to be @5.1, the TV play the file.Last edited by florinus; 29th Nov 2010 at 17:32.
  How convert MKV file with different mkv LEVEL (5.1 to 4.0..)By Nabucanezor in forum Video ConversionReplies: 19Last Post: 8th Nov 2013, 17:56
  AVC level 5.1 to AVC level 4.1 conversion?By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 08:57
  Profile level in TSmuxerBy ranosb in forum Video ConversionReplies: 3Last Post: 10th May 2009, 03:36
  Black Level setupBy Dr_Layne in forum Capturing and VCRReplies: 12Last Post: 4th May 2008, 19:56
  What Luminance level should I used with CCE?By mlong30 in forum Video ConversionReplies: 5Last Post: 19th Jun 2007, 11:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
