I wanted to edit some home video .VOB files and have been trailing VideoRedo TVSuite. Seems fine, no issues with it so far.
Hopefully a quick question, I take it that VideoRedo TVSuite cannot handle fade in / out?
I have looked at the Womble site and it appears that MPEG Video Wizard DVD 5.0 can do this. Is this correct please?
Many thanks for any info provided
Cheers
At the risk of inviting attack, I've recently been playing around with Windows Live Movie Maker and it does fades and many types of transitions. I have not tried to edit vobs, but if it doesn't handle them, it's easy enough to re-encode them into something compatible. Best of all WLMM is free if you are running Windows 7.
Windows Live Movie Maker is a curious beast. It seems to be more stable and handle more formats than the old movie maker, but then the .interface no longer has a proper timeline.
The big killer is that everything get's re-encoded, and WMV is very lossy.Read my blog here.
Many thanks for your replies.
Well I downloaded Womble MPEG Video Wizard DVD 5.0 and the fade in / out seems to work ok with that.
As a newbie to video editing, my only comment is that VideoRedo's offering seems to be easier to pick up but that is probably because it has less features.
As to buying both (gulp), not sure unless both those offering have half price xmas specials.
The only thing I would also add is as follows:
I cut / edit my video added fade in /out with womble and saved as .VOB file. I then tried to convert it to ipod size (320x240) with Handbrake (.mepg4) but on playback the audio was garbled (and video was also poor).
This did not happen with Handbrake when the .VOB files were edited with VideoRedo.
I could see that womble did allow for some type of mepg export although I did not notice mepg4 but I could not see how to set the size ie 320x240 as it kept exporting at 720.
Perhaps I just need to look harder.
Cheers -
Help for adding Fade In/Out and Joining many clips together
By joberrick in forum EditingReplies: 1Last Post: 11th Jul 2011, 20:44 -
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
