I've been playing with some mkv and found problems playing H264 (normal, level 4.1) profile video in MKV on the BD-C5300 player. Instead muxing the same video to mp4 worked without problems.. I created the MKV using mkvtoolnix and the mp4 using Yamb.
I previously had tested xvid in mkv which worked fine. Was wondering whether anyone had succeeded with H264 in MKV as the latter doesn't play for me. I'm testing on a usb stick not a burnt dvd.
I didn't succeed with idx subs in the mp4 though.
Try create the mkv with mkvtoolnix 3.4.0 or turn OFF header compression in mkvtoolnix 4.4.0.
problems splitting mkv files then playing on lg blu ray
By julie_152 in forum Video ConversionReplies: 6Last Post: 15th Jan 2013, 05:54 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Blu-Ray Turns off when playing MKV file
By Bobor in forum Newbie / General discussionsReplies: 9Last Post: 4th Mar 2012, 06:42 -
mkv to m2ts playing on my blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2010, 16:24 -
Samsung Blu Ray Player BD P3600 inconsistent in playing back copied DVDs
By ibramson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Nov 2009, 17:36
