Well here's how it is, I been using nero without menu's or anything of that sort and the I take my 3 mpeg compliant files and add them to be burned. Everything is fine it is less than 700 mb on the bottom then when I hit burn it jumps to about 750 mb as the Video CD size but thats normal I believe because vcd can hold up to 800 mb. Well I'm not sure what is exactly wrong but towards the end about the last 5 minutes of the third file the frames jump and everything freezes on and off and sound goes and and everything goes rough. I was wondering what is causing this is it because I have too much on the cd or something else some sort of Nero bug ??? any help would be appreciated
I'm not real thrilled with using Nero to create VCDs as it does not strictly follow the standards. VCDEasy is a much better tool for creating VCDs and you can take the image it creates and burn that safely with Nero if you wish.
As is often the case for new members, more info would be helpful. What exactly is your playback device? And if it's not a PC, have you tried playing your VCDs on a PC to see if they are OK there? One suggestion would be to try better media, either Taiyo Yuden or Verbatim. The other would be to try burning at a lower speed. Probably your problem is not Nero itself so I'd try one or both of my two suggestions first. -
What jman said.
Use VCDEasy: VCDEasy 1.1.5.2 freeware edition [DOWNLOAD]
Use TY blanks: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2F...reative=390957
Or Verbatim blanks: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2F...reative=390957
Test in computer.
Test in VCD-capable DVD player.
Done.
Watch VCD.
Or better yet, make DVDs.Want my help? Ask here! (not via PM!)
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 09:35 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 05:12 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23
