How is it possible to upscale and convert a file from a DVD source to that of a higher resolution than DVD specifications.
If a file has a resolution: 864 x 400 but came for a DVD source, would you consider this a BDRip, BDRip or DVDRip.
It would most likely have come from a DVD with the black bars cropped away and resized to keep the aspect ratio. However, since that's a ratio of 2.16:1, and since I know of no movies remotely close to that ratio, I might question the encoder's skills.
By cropping and resizing. No magic there since it's no longer a DVD.How is it possible to upscale and convert a file from a DVD source to that of a higher resolution than DVD specifications.
Upscaling DVD with 5.1 sound
By bunraku in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2009, 21:05 -
Upscaling SD to HD on DVD for HDTV ?
By yukon33 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 16th Dec 2008, 05:25 -
Upscaling DVD Players
By mf1462 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2007, 12:12 -
HD Upscaling DVD player...is it worth it?
By snadge in forum DVB / IPTVReplies: 7Last Post: 29th Aug 2007, 17:01 -
DVD Upscaling Issue
By Coder2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Jun 2007, 13:34
