I was on Yahoo answers, and this person asked which dvd drive is the fastest on the market. Someone replied that 24x is the fastest speed possible for a dvd drive. He said going any faster would cause the dvd to explode inside the unit. I don't think that's an intelligent answer, as the drive's motor is not the thing that would increase in speed. Just the drive's mechanics would go faster. The laser aperature would be zipping across the disc faster than a slower speed drive. I don't think that it would cause a disc to explode inside the unit, as the laser never actually TOUCHES The disc. It just floats millimeters above it. If the laser touched the disc, eventually you would have scratches galore.
Can someone clear this up for me, and maybe you could tell me which drive is the fastest on the market, and are there any drives in the planning stages that would go 50x, or 100x. Thanks!
				Results 1 to 11 of 11
	this belief is something that's been around for years and there is a grain of truth to it, as a disk spins faster the force exerted on it increases (force equals mass times acceleration and acceleration is a change in velocity over time, a change in direction or both), since there is always the chance that a disk will have a minor stress fracture from the manufacturing process (there's no such thing as a manufacturing process that has a 0 percent fault rate), putting such a disk in a drive spinning at 100x could conceivably cause it to "explode".
 furthermore, the spinning motion cause heat to build up, heat that is added to to that generated by the laser, it's not outside the realm of possibility that even a non-defective disk subjected to burning of data at 100x speeds may malfunction and splinter.
	Anyone can write anything in Yahoo Answers, and then it gets rated by someone equally clueless. Often when searching a link to them comes up and I read the "highly rated" answer, and it's complete bullshit.
 Anyway, my DVD player can fast-forward at 48X, and no explosions yet.
	A few years back, I had just installed a Plextor CD-R burner, went out and bought some blanks, I exploded two disks, I don't know how fast they were spinning but the drive sounded like a jet engine on viagra. The last one to explode ruined the drive. I have no idea the cause, but had to replace the drive and I've never exploded one since. It's not important the problem be solved, only that the blame for the mistake is assigned correctly
	It doesn't fast forward by spinning the disc at 48x, it moves the head like you would a turntable arm.
 I do remember seeing some videos where someone spun CDs faster and faster to see at what point they shattered. I seem to recall it wasn't too much faster than the equivalent of 24x DVD.
 It's not the video I saw many years ago, but a quick search on Youtube turned up this Mythbusters clip:
 http://www.youtube.com/watch?v=F6avp29GqXo
 A 24x DVD probably maxes out around 14,000 rpm. About half what it took for Mythbusters to shatter CDs. Their high speed cameras showed the discs warping severely well before they shattered though. That would make them unreadable.Last edited by jagabo; 28th Nov 2010 at 07:00.
	I still fondly recall a 1x DVD-R shooting out of a Pioneer 103 drive (16x read), slamming into a closet door on the other side of the room, and cracking severely. It missed my face by mere portions of an inch -- I could feel the air displaced by the disc on my nose and eyes.
 I've seen a CD-R snap in two inside a drive.
 It's about disc quality --- not speed.
 Yahoo Answers is mostly spammers, children/teens and idiots from what I've seen.Want my help? Ask here! (not via PM!)
	DVd's have been known to shatter, could be called exploding? and then the pieces do come flying out the drive at great rate of knots. FFx 48 doesn't speed the disc to 48x speed, probably about a third of that 16x. but 52x is reckoned to be max speed for reading CDr's less for reading DVD's. Corned beef is now made to a higher standard than at any time in history.
 The electronic components of the power part adopted a lot of Rubycons.
	I've repaired a creative 52x drive that had a CD explode inside, once. From the pieces that were left and the kids other discs, I concluded that the problem was caused by his abusing the discs when removing them from their case. Some people tend to bend the discs when taking them out, that causes small cracks to appear around the spindle hole. When a disc spinning at 52x starts to flutter the cracks can spread and multiply until one reaches the outer edge, then the disc explodes. DVDs are more resistant since they're made of 2 acrylic discs bonded together, but they get a different problem from bending. You see it with second hand discs from rental stores; bending causes the discs to partially separate and leads to playback issues.
	Seen it - if you're around discs, you will.
 That darn polycarbonate isn't indestructible.
 And - it doesn't take 24X to do it - I've seen it on an old 2X drive - it's up to the disc.;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
  Removed Esata drive and replaced with another drive. New drive is now unusBy cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17
  Is using a Bluray drive better than a regular DVD drive?By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49
  Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copyBy coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18
  Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcordersBy vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38
  Lite-On drive LH-16W1P DVD-DL driveBy snafubaby in forum MediaReplies: 8Last Post: 28th Apr 2008, 16:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
