Hi,
I recently parchased a WD TV HD Live media player and want to store my DVDs into and play them off a hard disk.
So I'm using 'DVDdecrypter' to create a VOB file for each DVD. So far everything is fine. Now I attempt to play these VOBs with my WD TV and find out - the hard way- that in order to see the subtitles, I have to extract the embedded in the VOBs subtitles into separate files (*.srt etc). So I search the net and stumble into the excellent program 'DVDsubedit' which does the job, only in my case there is a problem: DVDSubedit's OCR does not recognise my Greek subtitles and produces an srt file with strange and unrecognizable characters.
So please tell me, is there a way, a method, a program, whetever... to create a sensible 'srt' file containg non-latin characters properly coded? Or any other way to create a proper file of any type that could be used by the WD HD to properly display non-latin subtitles? Or even a way to permanently merge the movie file itself and the subtitles (as a graphical entity - not as text)) into a single movie file?
Thank you in advance
Rip to dvd iso files instead. Use dvddecrypter or dvdshrink to just strip out the main movie.
Could you please be more specific as to what settings to use?
Obviously I must have done something wrong, because I have tried both, dvddecrypter and dvdshrink ripping only the
main movie - as a single VOB file containing only one audio stream and one 'subpicture' - but with no sucess: The player plays
the movie ok but doesn't recognize nor display the subs .
Please, elaborate on the settings you suggest as I don't have much experience.
Thanks again -
No, as a single iso file. No vob file. Select Backup and choose Create ISO Image file in DVD SHrink.
How to Add Text Effects and Unicode Characters to MPEG-4 Subtitles
By PBear in forum User guidesReplies: 9Last Post: 20th Sep 2012, 10:15 -
Recommend stand alone media player that supports FLV files?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 11th Jan 2012, 04:01 -
Adivce on purchasing a stand alone media player online
By Cornholio77 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2011, 09:04 -
Is there a stand-alone multimedia player which will do subtitles?
By goanna300 in forum SubtitleReplies: 16Last Post: 30th Oct 2010, 05:14 -
[Solved] Serbian/Croatian subtitles in MKVToolnix (specific characters)
By brainstormed in forum SubtitleReplies: 0Last Post: 4th Sep 2009, 16:47
