What programs would be the easiest to use to convert and add an audio file to an avi video?
I have a wav file which I have edited and trimmed to the correct length to mux with the raw avi video, however I need as a final product an avi which has mp3 audio 128 bitrate, 2 channels so that it will match with the video which comes before and after this clip. If the codecs don't match up, I won't be able to join the clips.
Most of the programs I have are for video: Virtual Dub, Avidemux, Xmedia Recode, Movica
thanks for the help!
Last edited by mukluk909; 27th Nov 2010 at 22:05. Reason: fixed mistake mp2 should say mp3
Make sure you have Lame ACM installed.
Open the video in Virtualdub. Set Audio/Full processing mode.
Then select Audio/Audio from other file/ (point it to your wav file)
Audio/compression. Choose Lame mp3and choose your required compression on the right. (CBR works better).
OK out. Set Video/direct stream copy.
File - save as a new AVI
Mux many audio & video files to avi
By Urban20 in forum EditingReplies: 3Last Post: 29th Apr 2010, 04:35 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 03:22 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 17:52
