Hey,
I realize this question may just be dependent on my video source, I'm just looking for some general guidance here as I havent done much work with HD video.
I have a 1080p MKV bluray rip that is 11 or so MB/s, and I want to shrink it down to fit on a DVD-R, which means 5800kb/s.
My question is, for best quality at that bitrate, should I downscale it to 720p, or keep 1080p?
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
I would use 720p.
But why not make a ten minute sample or so and see how it looks like. Make a sample from the video that contains lots of motions and details. -
you should calculate the per pixel bit rate and go from there: 1080p is composed of 2,138,400 pixels per frame, and your source has a bit rate of 11,000,000 bits per second, assuming a 25 fps source that means each frame has a bit rate of 440,000 bits, for a per pixel bit rate of about .2 bits per pixel or 1 bit for every 5 pixels. that's not an awful lot.
720p has 921600 pixels per frame, which means that you could create a 720p movie, with roughly the same per pixel quality, by going as far down as 4.6 mb/s, assuming you use an equivalent quality codec as the source. thus 5.8 mb/s will be more than enough to maintain comparable image quality, sans the resolution, of course.
the above calculations obviously change if the frame rate is something like 29.97 or 30 fps. -
If the source is 1080p, then the best quality will be 1080p. What matters is your display device. At normal viewing distances, if the display is 50" or greater, then stay with 1080p. If the display is smaller, then the resolution loss of down conversion to 720p may not be objectionable.
At 5800 kbps it's likely it will look better at 720p. Unless it's a slideshow.
1080p vs 720p MKV Files
By esabet in forum Newbie / General discussionsReplies: 15Last Post: 24th Dec 2010, 20:27 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 10:57 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
How to get 1080p MKV -> 720p MP4 and keep subs?
By Knolly in forum MacReplies: 0Last Post: 3rd Jun 2008, 02:01 -
MKV file plays in 720P, not in 1080P
By dacolajr in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2007, 12:51
