This seems crazy but I cannot seem to find any burning software that will show me the exact space remaining when adding files to a compilation. All seem to just have a very rough bar graph and not an exact number. This is very annoying when trying to fit as much as possible on a disk. Some programs like Nero show you the maximum that will fit and the amount you have added. This would be ok if they calculated them the same way but no the bar shows in GB while the disk max shows in MB. Is there any burning software that will give me a number for space remaining when adding files to a compilation? Why is such a basic need seem to have been overlooked by so many software companies?
webmaster@obsessedwithanime.com
http://www.obsessedwithanime.com
Cosplay - Images - Convention Reviews
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 07:47 -
burned dvd shows nil in used space
By sumeshkri in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2010, 21:41 -
My comp turned off when burning to Nero, now lost HD space, where will the
By BostonPatriot in forum Newbie / General discussionsReplies: 14Last Post: 8th Jul 2008, 01:42 -
DVR650 Pioneer DVD recorder shows zero hours remaining
By jackdup in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th May 2008, 17:24
