Hi guys, been a while. Backed up Twilight Eclipse with DvdFab 7070 today, which seemed to go Ok. I used the 'main movie' option as usual. When I burned to disc and reviewed the disc I realised that all was not well. It froze three seconds into the movie, I skipped over that part , but viewing further down the line I realised that 'chunks' of the movie were missing. A few minutes from the beginning, a few more minutes later on, and so on. It was like they were just edited out while the movie continued on. I confirmed this by reviewing the original. What gives ? Is this a fault of DvdFab, or some kind of new protecting ? I'm baffled. Anyone come across this ?
Will try that, thanks Wizard. Still curious about what kind of protection this is though. How does it manage to 'dissapear' whole sections of the movie ? If you don't see the movie previously, you don't maybe even realise somethings wrong with the backup.
Well, DvdFab 8052 seems to have done the trick, thanks for the suggestion Wizard. Out of curiosity I scrutinised what happened this time. I did 'Fulldisc' option, and saw that there were TWO dvd titles created. One was the correct one, which I chose, another which is a 'cut up' version about 12 minutes shorter. Strange.
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 18:41 -
July 22, 2009 the longest solar eclipse of the 21st century
By freebird73717 in forum Off topicReplies: 3Last Post: 23rd Jul 2009, 09:39 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 18:19 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 06:47 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48
