I'm trying to get around facebook's thing where you can post a video in a multitude of formats, but you can't post an audio file like mp3.
I want to see if I can create a "video" file in one of facebook's accepted formats (e.g. AVI, MP4) that actually doesn't contain any video, just the audio. Then I could post that to facebook, since it would appear as just a normal video.
Can I do that with ffmpegX, i.e. convert an mp3 audio file to a video file that actually contains only audio? Looks like there should be a way, but I can't figure it out.
Also, if the video must contain something, can I put in some still image?
No you couldn't; no it wouldn't, since there's no video.
That's the obvious way to do it. YouTube is full of songs accompanied only by a picture. I don't use Facebook but assume it's the same there.Also, if the video must contain something, can I put in some still image?
Yes! That's what I want -- a "video" where the video track is just a still image, or even blackness. I should be able to post that to facebook as a video, even though really it's just audio.
So I need a program that will generate a specified length of video file, whether it be blank or a still image, to which I just add the song I want to post. Hm, I think iPhoto will export a video version of a slide show -- that might be the ticket.
Thanks, Jagabo, but I'm on a Mac (Mac OS X 10.6.5) and VirtualDub is Windows-only.
I think I can do what I want with iPhoto.... Will post Mac-based solution if I do.
Convert .exe video tutorials(built by Screencam) to video format
By cyforex in forum Video ConversionReplies: 3Last Post: 1st Apr 2012, 17:11 -
Convert video in BYGB format
By radler12 in forum Video ConversionReplies: 1Last Post: 21st Aug 2011, 11:22 -
MD video file format - how can I convert it?
By bahjan in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 09:05 -
What should I use to convert video to PS3 format?
By hanugro in forum Video ConversionReplies: 4Last Post: 20th Mar 2009, 05:13 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 07:47
