First of all sorry if I have posted this in the wrong place.
I just have one question. I just burnt a dvd using avstodvd program. During the 3 hours there was no problem, but when it got to 95% of the whole process an error came up and the whole process got aborted. This was after Imgburn had burned, verified and ejected the tray. Now when I play the dvd the images/video content seems to work great, however the audio is messed up. They sound like chipmunks
The files were in .mkv format if that helps.
Any help would be greatly appreciated![]()
MrC, the author, regularly visits this forum, so you should get a reply from him soon.
In the meantime you should post the log file created during the run, it normally gets stored in the output folder. -
Just converted the files to wmv format and then tried burning again.
This time the sound is fine but isn't in synch with the images
although they don't sound like chipmunks anymore
Also I think I figured why the process aborted message came up, it was because when Imgburn was burning the dvd I checked the verify box and eject disc after comepletion box. Therefore the dvd was ejected and avstodvd program showed process aborted message
Meaning the dvd was burned and verified so the audio/sound problem isn't linked to the process aborted message on avstodvd?
I suppose maybe I should try a different format? I was going to use avi originally but last time I did that it didn't play on normal dvd players but did on a friends dvd player (maybe cause it was DiVx certified?
@Starry
1. Please post the AVStoDVD project .log file, as dave already has suggested.
2. The error msg after burning is due to the fact that AVStoDVD try to read if there are the DVD files (ifos and vobs) on the DVD. If you toggle on 'eject after burn', no DVD is there to be read...
3. Very often audio encoding errors are due to bad (or badly configured) codecs. Be sure you have Haali Media Splitter and ffdshow installed, and eventually check your directshow decoding chain with GraphEdit.
Bye -
Hi there,
I'm having a similar problem, although i haven't tried any other formats yet, i have both haali media splitter and ffdshow installed but the sound is still like chipmunks plus theres a hissing sound also.
Not sure what i'm doing wrong but mines is also in mkv format and the sound works fine on my computer, not sure why it happens on the dvd.
I have my log at the attempt, should i post it here or would that be hijacking someone elses thread?
P.S. im also using avstodvd prog.
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
Avstodvd program
By Starry in forum Authoring (DVD)Replies: 1Last Post: 26th Nov 2010, 14:49 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 07:29 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 05:01
