I am a severe newbie to h264 stuff...I just graduated to a new win7/64 computer after living with a 6 year old win xp model. I'm trying to convert a .avi file encoded with h264 to a dvd. Tmpgenc 4 authoring works is giving me the dreaded "cannot open the video part" of the file, etc. I'm not exactly sure how to proceed.
The file will play on my computer with vlc and wmp. Gspot says codecs are installed. I don't have ffdshow installed...yet...
I'm not sure how to proceed, but thought I could try getting some expert advice. I don't want to try installing a bunch more garbage in the hope that it will work.
The torture never stops!
You use avstodvd. I guess it also can convert to mpg files that you can import in tmpgenc authoring works.
The usual method is to ensure you have the directshow codec installed (perhaps FFDshow or CoreAVC)
and then enable the dshow plugin in Tmpgenc.
AVStoDVD is an all-in-one package. It creates the m2v video and ac3 audio and combines them into the video_ts folder structure,
which you can then test and burn. Optionally, you can ask AVStoDVD to keep the intermediate files (m2v and ac3)
which you can then drag into Tmpgenc for the authoring. (Another option). -
Thanks for all your advice guys.
I did finally get it working by using the advice in post #5 (installing Shark007) in this thread: https://forum.videohelp.com/threads/309626-need-help-importing-MKV-files-into-Tmpgenc-Xpress-4-under-Win7-x64-please
TMPGEnc Authoring Works 5 Version & HD-PVR Question
By TBoneit in forum Authoring (Blu-ray)Replies: 25Last Post: 18th Nov 2015, 18:20 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 08:32 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15
