Hi, i want to play x264/H264/MKV files on my laptop,VLC can play these files, can i use divix player to play these files for better sound & video quality?before i used watch movies using power dvd 9, but since started converting all movies to H264 content, i expect same sound & video quality that power dvd gives. any advice will be greatly appreciated, THANKS IN ADVANCE
Skorpinok
If you install the required codecs it should with divx player and probably also powerdvd. Install for example ffdshow.
BUT I doubt you will get any better quality than VLC. -
i will use MPC Home cinema,power dvd 10 plays mkv files, but h26/mkv in power dvd shows pixelating,dark spots.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Is divix player good?
By skorpinok in forum Software PlayingReplies: 2Last Post: 7th Aug 2011, 09:52 -
Player nightmare! (BS Player and Media PLayer Classic)
By 2710 in forum Software PlayingReplies: 1Last Post: 9th Jul 2010, 06:28 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 17:45 -
conversion to divix
By ari dubov in forum Video ConversionReplies: 2Last Post: 12th Jun 2007, 01:56
