Hope you guys can help me!
I have the 1.68 firmware and tried my Pioneer burner as master and slave; in both cases I get either a communication failure message, invalid block address (with Nero) or logical unit communication tiem-out (with Instant CD+DVD) when trying to burn CD-R(W).
I also tried uninstalling my CD burner (Teac CD-W54E) unsuccessfully!
The weird thing is that I have no problem burning DVD-R(W).
Anyone knows the cause of this problem?
are you using low speed rated cd-rw media ( 4x ) as it will not use hi-speed ( 4x-10x) rated cd-rw media
I am indeed using 4X CD-RW. But I get the same results with CD-R's burning at 4X or 8X...
you say tried unsucessfully unistalling yout teac cd-r, that should be easy as removing it from the computer, swapping the pioneer for it ( asuuming it's master on the channel ) and rebooting back, no drivers are needed for the cdr part, ( mine didn't and I had a plextor 24x that I moved to another system ) or the DVD part , DVD-R and DVD-RW worked fine off the bat in Nero. All I can think of is that at one point you had ezcd installed and that screwed the apsi layer.. but Nero uses it own aspi layer and ( newer versions of Nero ) and does not need the aspi layer installed. I am at 5.5.7.8 of Nero and it's the first app I install on both my win2k machines and both work fine without the apsi layer installed, I only install the apsi layer for the benefit of Clone cd as Nero will do bin/cue files natively ( has done so for quite some time ).
one last thing, check for heat build up, I found since I left this computer up and running 24/7 the pioneer would get hot and thus fail on a burn, cd-r, cd-rw or dvd-r,dvd-rw, or even refuse to recognized any blank recordable media, my solution in my case ( since it a min atx ) was to get a heat sink / fan cooler that mounts directly below my a03 and has 2 fan that blow air across the heatsink, this has solved my cooling problems on my a03 and now i do not get failed burns at 80% ( where most of them were occuring or so ). The odd thing is I have an older tower with a scsi dvd-ram drive recordable and it too suffered from the same fate, it just been a while since i remembered that problem and applied the fix to my a03.
I didn't express myself correctly about uninstalling my cd-r burner. What I meant whas that I di uninstall it, but the result was unsuccessfull... it didn't change anything.
About a possible heat problem, I don't know. Why would I able to burn dvd-r and not cd-r if I had heating problems?
Other suggestions? Anyone?
yamada DVR 9000 won't start :(
By mwg in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Jan 2010, 09:24 -
DVR-112D Won't burn or read any DVD
By Genwifa in forum DVD & Blu-ray WritersReplies: 3Last Post: 3rd Oct 2008, 02:36 -
Pioneer DVR-531 TV Guide won't come up
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Aug 2008, 21:17 -
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
Pioneer DVR 212D won't read Some CD's
By Regm in forum DVD & Blu-ray WritersReplies: 10Last Post: 31st Jan 2008, 17:31
