Hi there, apologies if this has been answered already but I haven't managed to find the right info as yet.
I have a video project where a .ts file is played from a CF card through a Bright Sign display system.
My issue is I have been asked to add subtitles to the film - I have used Jubler to do this and then Submerge to create a lossless .mov with subtitles. All good so far, however, when I then convert my lossless .mov to .ts (using Tipard total media converter) I lose the subtitles.
Can anyone suggest any solutions to the problem as my final .ts needs to contain the subs due to being played from the CF card?
Many thanks for any help with this!
Results 1 to 10 of 10
Thanks for the reply, but it seems I can't get a version of tsmuxer to work on my system. It would probably be best to hard code them though as they never need to be changed and it may be more likely to play on this CF based system?
Can you advise on the best way to hard code the subs into the ts file?
Many thanks! -
Looking at the Bright Sign specifications I couldn't find any mention of subtitles, so maybe if you produce a burnt in subs version may be the solution?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hi thanks for the suggestion - could you clarify what you mean by 'burnt in' though? To be honest I think that's what I'm trying to achieve but just not sure of the best way to do it...
Burnt in = subtitles permanently displayed and non switchable. ie like a video overlay as opposed to say what's on a DVD or Bluray where you can turn them on or off or select a particular language etc.
That sounds ideal - I thought I had already achieved this though at the .mov stage but then when I convert it to .ts I lose them. What would you suggest is the best method to achieve the ts file with burnt in titles? Are you meaning do it at the video editing level e.g. after effects?
Thanks again -
I don't suppose anyone can offer any other alternatives here or suggest the best way of hard coding the subs into the .ts?
My original movie was made in after effects but I don't have the pro version which means I can't run scripts (otherwise I would have made an .ssa file and imported that).
I have also tried running the following expression in AE:
type = "Lorem ipsum dolor sit amet, \consectetuer\ adipiscing elit. Donec eu tortor. Vivamus elementum massa et nibh. Mauris aliquam nisi ac tortor. Praesent vel massa. Quisque aliquam gravida dui. Praesent ornare, velit et sollicitudin sodales, nisi lacus vehicula pede, ut bibendum ipsum dolor nec dolor. Aliquam pulvinar fringilla ante. Phasellus luctus tortor laoreet lorem. Proin odio. Nunc sem. Nulla facilisi.";
sentences = type.split(".");
n = Math.floor(effect("Lines")("Slider"));
if (n>=sentences.length){n=sentences.length-1}
if (n<=0){n=1}
lineBreak = effect("LineBreak")("Slider");
line = sentences[n];
if(n>13){n=11}
if(line.length > lineBreak){
"" + line.slice(1, lineBreak+1) + "\r" + line.slice(lineBreak +1, line.length);
}else{
"\r" + line + ".";
which i found online but it keeps returning errors and misses the start of the subtitles!!!
I can't believe how fiddly this is - surely there is a simple solution - can anyone help?
Many thanks
New here, I am having troubles with displaying subtitles on my pc!!!
By Luciauruguay in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2010, 10:31 -
Subtitles in MPC displaying as splashes of dots
By meldavid in forum Software PlayingReplies: 3Last Post: 27th Aug 2009, 23:47 -
displaying the movie subtitles in samsung ht-x30 player
By jonax00 in forum SubtitleReplies: 0Last Post: 11th Jun 2008, 21:37 -
Subtitles displaying too early!!!!!
By NextJinGamer in forum SubtitleReplies: 0Last Post: 17th May 2008, 13:35 -
Displaying Subtitles from file on computer while playing a DVD
By mrdemanding in forum Newbie / General discussionsReplies: 4Last Post: 10th Mar 2008, 08:15
