I have several movies I captured full quality from my DV camcorder, so they are in uncompressed AVI format.
Frame Size: 720x480, 25fps
Decompressor: Microsoft Video 1 (CRAM)
Data Rate: 17783
Audio Sampling Rate: 44100kHz
Channels: 2 stereo
Compression: PCM (uncompressed)
Data Rate: 1411 kbps
I want to put together a DVD movie. Should I compress them first, and then use some software to convert them to a format suitable for burning to DVD i.e. MPEG-2? Or would it be easier to do a straight conversion to the DVD compatible format?
If so would AVI Demux do the trick? And what settings would I need?
The problem is the files are huge, and probably difficult to process on my laptop, so that's why I was going to compress them first. Most of the movies are 6-9Gb
THanks in advance
If they are really MS Video 1 (CRAM) then they are not full quality from the camcorder. CRAM is a very old, lossy, low quality (by modern standards) Microsoft codec. They should be DV AVI (usually the fourcc DVSD). That would be an exact copy of what's on the DV tape. Use a program like DVIO or WinDV to capture from the camcorder. You can also use Microsoft Movie Maker. Just be sure it's set to DV AVI, not WMV.
You also have something screwy with the frame size and frame rate. 720x480 is an NTSC frame size and should be 29.97 fps. PAL would be 720x576 and 25 fps.
If you can, you should go back and capture the video again as DV AVI. In any case, you need to convert to MPEG 2 with DVD specs to make a DVD that will play in any DVD player. Look at AvsToDVD, or:
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=DV+t...or+List+Guides
And all the decent commercial video editing packages are capable of doing this. Corel VideoStudio, Sony Vegas Movie Studio, etc.Last edited by jagabo; 25th Nov 2010 at 21:19.
Thanks Jagabo
That's great advice. I'll give those things a go, and report back
compress video
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2009, 04:43 -
I need to compress video to DVD but the quality is always lower...
By tzanaglio in forum Authoring (DVD)Replies: 6Last Post: 30th Apr 2009, 18:48 -
compress DVD video
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2008, 19:04 -
Compress Webcam Video Stream (Video Conference)
By wxrkny in forum Newbie / General discussionsReplies: 1Last Post: 6th May 2008, 00:11 -
how do you compress video
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 14:21
