Hi, I am about to burn some AVI files to DVD using AVStoDVD. Actually, I have burned the same files to DVD once before, and that time it went great.
But this time, when I add the first AVI (which is 528MB in size) the output size is reported @ 3399MB, i.e. some 76% of the DVD..!?
And, of course, if I add the other two AVI's that went into the DVD last time, I get an error message when it comes time to burn.
What is wrong? How can 528MB translate into 3399MB? How come it worked last time?
Thank you.
Ignorance more frequently begets confidence than does knowledge.
VStoDVD attempts to maximise the use of the available space to maximise the quality of the video. Is you use AVStoDVD you are converting to a DVD compliant format (Mpeg-2). The important this is not the size of the source video, but the running time. Different codecs compress differently. An Xvid/Divx video converted to mpeg-2 usually requires around 3 - 4 times the space of the original to maintain the same quality. At the maximum available bitrate, 3400MB is around 44 minutes or so of video. If you add more video to the compilation (i.e. add another title), the bitrate will drop (as will the quality, potentially), to accommodate the size limit (DVDs have finite space, after all). This should happen automatically (it does for me), so I don't know what problem you are having.
Perhaps if you explain what you are using for burning, and what error message you are getting.Read my blog here.
Thanks for replying guns1inger. You say: "Perhaps if you explain what you are using for burning, and what error message you are getting."
I use, or rather AVStoDVD uses, IMGBurn. The error message, I think, was something to the effect that 'there is not enough space on the disc, do you want to continue anyway?' to which I must have answered 'yes' last time, since I got a quite watchable DVD out of it.
No quality issues as I recall. Yes, the bitrate is apparently automatically adjusted.
I appreciate the explanation, again thanks
AtwoodLast edited by VenusAndMars; 25th Nov 2010 at 17:13.
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 20:27 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 06:54 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 02:29 -
Problem with DVD output size
By senecalax25 in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2008, 03:08 -
Different DIVX codec, different output size.
By DonGallego28 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 09:08
