Have FLV capture at 23.976 that I want to convert to NTSC VOB at 29.97. I have tried to save as a VOB with Aiseesoft Total Video Converter set at 29.97 and other methods. Problem is jumpy VOB. I have demuxed with DGIndex and put pulldown flags with dgpulldown, etc. Nothing seems to work.
I'd also suggest a better conversion program. It sounds to me like the 23.976fps source is being converted to progressive 29.97fps by the addition of a duplicate frame after every 4 frames where it should be encoded as progressive 23.976fps with pulldown applied. You can check by advancing a frame at a time looking for the duplicate frames.
Either that or you're not using this Total Video Converter properly. Try setting it to 23.976fps and maybe it'll apply the pulldown for you so that it'll output interlaced 29.97fps. Since you're familiar with DGIndex, open an output VOB and run the Preview. If it says Frame Type:Progressive and Video Type:NTSC, you or the program screwed up. -
Finally used HCenc with CQ1 and pulldown with DGIndex files and got it smooth. Somehow DGPulldown couldn't do it.
Thanks, Guys.
convert .mov or vob file to .flv
By Giacomo in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 13:03 -
.vob to .flv conversion
By mayur in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2010, 09:04 -
encoding .VOB to .FLV with least loss in quality
By altavistasf in forum Video ConversionReplies: 9Last Post: 15th Oct 2010, 18:33 -
Convert from VOB to FLV
By CREWorld in forum Video ConversionReplies: 2Last Post: 3rd Jul 2007, 01:17 -
VOB to FLV, or at least to a usable MPG
By YoKnows in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 19:14
