I have a high spec machine (Athlon 1300, 512MB, AtA100, windows2000 NTFS etc).
I have some VHS tapes that I want to make the best possible digital copies of.
I was thinking capture at the highest setting AVI and then compress afterwards with divx or something.
Which card should I use for the capture! I don't want to spend more than £200 or so.
- seb
my choices as I see it:
Pinnacle DC10+
ATI All-In-Wonder of some sort
Hauppauge WinTV PVR -
TV card wise, avoid the WinTV GO because it is a monaural card.
A cheap TV card (w/stereo sound) will give you just as good results as a more expensive capture card such as the WinTV PVR, All-in-Wonder, etc.
What you get is a trade off. The cheaper the card, the more time you're going to have to spend to make the digital file, whether it's MPEG-1, MPEG-2, or whatever. In general, more money = less time spent. -
I believe the PVR is the only Hauppauge product that captures at full D1, so I doubt if many of the cheap other brand TV cards do either.
- seb
NOOB trying to transfer video from Vixia HF200 to Sony Vegas
By Robb Rugg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Jun 2010, 15:19 -
Which video editor for this effect? (a noob question)
By thea in forum EditingReplies: 5Last Post: 26th Apr 2010, 08:51 -
noob-help! plzzz! video-ts folder files export to something i can use...
By shedev in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 14:27 -
Total video noob, need to edit & convert videos
By HDn00b in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2009, 01:58 -
Complete video noob with lots of questions..
By roper512 in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2009, 22:58
