Hello all,
I'm pretty new to Linux, so please bear with me.
I've been converting my own DVD's to ISO files for years now using Windows programs (AnyDVD, DVDShrink, DVDFabDecryptor and various other software tools).
I'm moving several of my PC's over to Linux Mint now, because I've had it with Microsoft (for personal reasons, please don't hijack this thread to express your grievances about them). But I need to know what software to use to do what I was able to do with my Microsoft PC's
I typically converted DVD9 discs to DVD9 ISO images (no compression of the files). Most of the time I remove all of the menus. However, for my TV show DVD's I keep the menus, basically making an exact copy. I also make individual ISO images of each TV episode, in case I don't feel like having to go through the whole menu to watch a specific one.
So what software will allow me to do these 3 types of conversions?
What settings do I need to modify to get this done?
Anything else I should be aware of?
I know this is a lot to ask for in a single posting, but I didn't want to make 3 different threads.
Thanks for all of the help.
Results 1 to 9 of 9
Are you registered as human?
Negative, I am a meat popsicle! -
Not sure what native linux programs will do what you want but if you don't mind installing wine on your systems then you can use dvdfab (the free version -- note that as far as I know the paid version doesn't work in wine) and dvdshrink.
Both work perfectly fine in linux by using wine. Use dvdfab to get the dvd's to your hard drive. Then use dvdshrink to create your iso's however you want by using it's reauthor feature.
Not really a purist nix way of doing things but it does work just fine.Donadagohvi (Cherokee for "Until we meet again") -
I'd like to be able to use Linux programs, hence the heading of the post.
I had thought of using Wine to do that, but some of my PC's are quite a bit older. Going to Linux was a way to free up resources so that they could do a better job of ripping/encoding.
Thanks for the suggestion. I will keep it in mind if I get no other answers here.Are you registered as human?
Ok. But realize that wine requires no overhead. A windows program running in linux by way of wine will use the same amount of resources as it would running in windows.
http://linux.about.com/od/softorther/a/softotherwine.htm
I've personally had very good results using dvdfabhddecrypter and dvdshrink in wine. They are programs that you are already familiar with and will work just the same with no lose of resources or productivity.Originally Posted by Above Linked Article
There are a few nix dvd rippers , two that comes to mind right off the bat are dvd::rip and dvd95, but the nix rippers don't get updated as often as dvdfab does and they can't handle newer copy protections.
I've never used either though so I can't tell you their effectiveness.
You can also check out our linux tools section
https://www.videohelp.com/tools/sections/linux-video-toolsDonadagohvi (Cherokee for "Until we meet again") -
I have tried K9copy. My problem with it is that it always tries to convert the rip to a DVD5 when I want it to be a DVD9. Unless I have missed something, maybe a setting that can be modified?
I handn't realized that there was no overhead using Wine. Then I can still use my AnyDVD and DVDShrink, as well as AnyDVDMobile (for mp4's).
Well, thanks a bunch! That really helps out. I'll take a look at that this weekend.Are you registered as human?
I've not tried anydvd with wine but from what I've read it doesn't work.
However dvdfab (free version) does work.
For information about whether a certain program will work with wine or not just look it up in the wine apps database.
http://appdb.winehq.org/objectManager.php?sClass=application&sTitle=Browse%20Applicati...Ascending=true
They give a rating system from Platinum (meaning perfect) to Garbage (meaning doens't work at all).
Here is the reviews for anydvd
http://appdb.winehq.org/objectManager.php?sClass=application&iId=6361
Reviews for dvdfab
http://appdb.winehq.org/objectManager.php?sClass=application&iId=2377
Revies for dvdshrink
http://appdb.winehq.org/appview.php?appId=1533
Some apps work great. Some work pretty well. Some don't work at all. Not a perfect solution by any means. But for a great many programs it works just fine.Donadagohvi (Cherokee for "Until we meet again") -
Have you tried k3b? It can rip dual layer DVDs to a single ISO image.
I can't recommend any easy to use programs for ripping or DVD authoring, as the ones I've tried have been buggy/unreliable.
I usually use mplayer to rip content, dvdauthor to create the DVD structure and growisofs to burn back to disc. All three are command line programs.
Don't rule out using wine - as freebird73717 says, it often works well. -
That's easy to do.
Use vobcopy to mirror the disk to your your hard drive. (It will remove any copy protection)
Then use k3b to burn it back to disk.
This what I do all the time to make copies of my DVD9's.
By the way I refuse to use any window programs including those I could use wine with.
Trying to choose a new camera
By jlbgt2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2010, 18:41 -
What's a good program that lets you choose end file size for AVI?
By THRobinson in forum Video ConversionReplies: 6Last Post: 5th Apr 2010, 21:42 -
Which notebook you would choose from these 2?
By alintatoc in forum Off topicReplies: 1Last Post: 27th Jan 2009, 22:00 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 21:27 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 11:23
