Can any dvd players read photo files (jpg or others) like they do with mp3 files?
You may be very interested in my new post......
there is a brand new JVC model that indeed does EXACTLY what you ask about.........
it is the XV-S500BK
this is the model number in Canada though.
if you go to www.jvc.ca you can see it as one of the models listed.
Futureshop.ca ( www.futureshop.ca ) has just begun selling the model
300....... XV-s300 and is going for $229 I think ? .... I was on the site last night but can't recall....... this is a new model they are selling , so I wonder if it will be a long wait before the 500 shows up.
Mark. -
Or you can get the APEX 1100w from Wally World for $70.00 that plays everything.
WallyWorld ( Wallmart) doesn't sell Apex DVD players, I'm about 99% sure of it.
I'm guessing U R in the States also, with a price of $70 .
For $70 here in Canada you can buy a hamburger and fries, that's about it
Most players should if you burn in iso9660 format and closed session
(disk-at-once). -
Well... When I did buy my Apex's (both of the same model, they break down, so DON'T)... they were from Wal*Mart... so correction made!Originally Posted by logopro
Basically, I think most (if not all) players that support PBC will also support a video slideshow...
It depends on the program generating it, I don't know if burning the jpeg's directly (outside of the VCD folder layout) will work on many models, andI can tell you that the slideshows that NERO puts out are flaky.
Good luck! -
http://www.walmart.com/catalog/search.gsp?dept=3944&search_query=apexOriginally Posted by logoproAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 12:53 -
M-JPEG codec
By cheerful in forum Software PlayingReplies: 1Last Post: 3rd Mar 2010, 19:43 -
Morgan M-JPEG configuration?
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2009, 04:46 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 16:53 -
saving video as jpeg
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2007, 08:38
