As many of you know, Toast gives you the option to choose Never when re-encoding (as seen below). So, shouldn't the rest of the video options become muted/non-selectable as soon as you choose Never?
Does it really burn to DVD without changing the video quality one bit?
When encoding for DVD, "Never" only applies to MPEG-2 files (perhaps MPEG-1 too?). All other files will be re-encoded anyways. It's sort of the "Automatic" re-encoding setting that actually works.
The "Automatic" setting sometimes re-encodes clips that you know to be compliant. Switching to "Never" prevents that needless re-encoding.
If you have multiple clips for authoring, some compliant clips will not be re-encoded, while other non-compliant clips will be re-encoded to specs. Hence the other options are still valid and should stay active/selectable.
Well, that's my experience anyways. Regrettably the user manual isn't more clear about that.
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
losing subtitles when burning with Toast
By mmax102 in forum ffmpegX general discussionReplies: 3Last Post: 2nd Nov 2008, 08:34 -
burning clips with toast
By 3mselect in forum MacReplies: 6Last Post: 29th Oct 2008, 12:54 -
After burning in Toast: subs: no and yes.
By Levina in forum MacReplies: 7Last Post: 13th Apr 2008, 16:50
