Hi,
I have a small video size 320x240 with pad quality. I want to resize the video to be 640x480 and improve the quality. Is it possible to do that ?!
Sample:
http://www.mediafire.com/?2ic0oahg2b7do16#1
Best Regards,
SB4
What is pad quality? Do you mean bad quality? The answer is no. Resizing means reencoding which loses quality and you are making the resolution bigger which does not improve anything.
Your best bet is AviSynth:
To resize:
But, you may also need deblocking, tinting, sharpening, denoising and/or grain, etc. It won't be easy, but at any rate, the best you can do is make it "look better", not "improve the quality".Code:LanczosResize(640,480)
I hate VHS. I always did.
Improve video quality [HELP]
By v1rto in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2011, 09:46 -
Resize and Improve the quality with less time process
By SB4 in forum RestorationReplies: 23Last Post: 31st Jan 2011, 06:13 -
What can I do to improve my quality?
By Captain Satellite in forum RestorationReplies: 12Last Post: 27th May 2009, 12:06 -
How to improve picture quality
By MI6 in forum Video ConversionReplies: 2Last Post: 25th Feb 2009, 17:37 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
