Ok, so I decided I hate VLC. Everytime I play MKV files with it, it's always choppy and "studders". As a substitute, I use Mplayer for OSX and even Hawkeye for playing my MKV files. The problem is that I have 2 MKV files in particular that have no audio while playing them except when I play the files using VLC.
Has anyone ever heard of this kind of a problem? and if so, know of any fixes for it?
Again, forgive me if this is on another thread, but I had no luck in trying to find an answer...
thanks in advance.
Results 1 to 12 of 12
jagabo is right. The TV I use to play MKVs on is 1080p.
So I just need to find and install audio compression decoders? -
I believe so. But I don't know for sure. I've never used it.
Windows (and other operating systems) usually bounces single threaded programs around between multiple cores to spread out the heat. So you may see all cores being used. But the thread is never running on more than one core at a time. If you look at the total CPU usage while playing in VLC you'll see it maxes out around 50 percent on a dual core cpu, 25 percent on a quad. It will occasionally go over those values because there is more going on than just the h.264 decoding. -
First check in VLC (the Information window) what audio codec(s) was (were) used in your problematic MKV files.
Can I save a Video/Audio being played on WMP/VLC/KMPlayer?
By ConverterCrazy in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2011, 01:27 -
VLC 1.1.10 not playing MKV
By pooksahib in forum Software PlayingReplies: 2Last Post: 1st Jul 2011, 04:49 -
VLC not playing MKV
By stringcheesy in forum Software PlayingReplies: 1Last Post: 19th Mar 2011, 04:29 -
MKV cannot be played, even with VideoLAN
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 29th Dec 2007, 03:12 -
AVI file "broken" when played with VLC
By Salva Veritate in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2007, 13:01
