  1. I'm trying to render to AC3 with Vegas Pro 9e but it's telling me I need DVD Architect installed, which I do have. I tried un-installing and re-installing and that doesn't work.
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I just tried it with an MP3 and it works fine. I DO NOT have DVD Architect installed. Also using 9.0e.
  3. You tried rendering as MP3 or importing an MP3 and rendering as AC3?
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Mp3>ac3
  5. I can't render anything to AC3. I am working with PCM WAV files in my project I need to render.
    The AC3 Studio basic template works but AC3 Pro whether I try to customize or not gives me the error.
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I didn't try the pro, hang on.
    EDIT: Yep, same message, need to install DVDA AND register.
    I don't even use DVD's anymore, so I can't help much.
    Apr 2004
    Miskatonic U
    In order to output Pro AC3 from Vegas you must have a license that is separate to the initial Vegas license. This can either be purchased as an AC3 license, or comes included with DVD Architect. Hence installing DVDA (and registering it) should solve the problem.
    There is an AC3 Studio option, which has little or no customisation and allows for stereo output only (at least this is the case in Vegas 8 Pro). This should work without DVDA.
    Read my blog here.
