Everything is in the tittle !
I have just ripped a DVD and when I extract the ac3 creating the d2v before encoding, I notice that it's shorter than the video stream by 2s. So the Video is out of sync. and I can fix it beceause it s progressive desync "by level" (not fully progressive indeed)
Do you have any idea ?
Results 1 to 10 of 10
Perhaps it was decrypted incorrectly. Is it a newer movie, and what did you use to decrypt it?
The out-of-synch, is it off by the same amount all the way through, or does it get worse as the movie goes along (maybe starting out OK but getting worse with time)? Or, is it OK for awhile and then at some point maybe 'jumps' to an obvious out-of-synch? -
Sometimes the audio can be a second or 2 shorter than the video and still be in sync,just encode and mux and see if it stays in sync on the final video.
a) I used dvdecrypter and dvdfab last version, and it's still out of sync. The decrypted vob on my HD are in sync, but the problem comes when I encode it using megui, the muxing is out of sync.
b) Yep That's the third proposal. It's OK for awhile and then at some point maybe 'jumps' to an obvious out-of-synch. -
OK, open the IFO for the movie in PGCDemux. Instead of the default mode 'by PGC', tick 'By VOB ID' and check the drop-down box to see if there's more than one VOB ID. If there are two or more, next see if it all of a sudden goes out of synch where the VOB IDs change. If so, then the audio for the one VOB ID is shorter than is the video for that same VOB ID. Sometimes, less often, there's a delay in the second VOB ID. You can check for a delay in any of the VOB IDs by highlighting one of them and hitting 'Check A/V Delay'.
Edit: I interrupted my reply to go do something else. If what I described is true for you, AlanHK's reply is the answer - split it at the jump (or demux by VOB ID), fix the delay, and rejoin. -
Very late -due to some heavy problem with my computer- thx to mananono and AlanHK. I Understood the reason of the problem and a got solution to fix it, I just need buy a womble licence cause I didn't find a free tool with the same quality.
True-HD to ac3 extraction
By bldblu in forum AudioReplies: 10Last Post: 27th Jun 2013, 02:40 -
Increase framerate without making the video shorter (or longer)
By FallenAngelII in forum Video ConversionReplies: 7Last Post: 7th Jul 2010, 16:02 -
Converted audio shorter than video
By rjc7394 in forum AudioReplies: 0Last Post: 15th Jun 2010, 00:14 -
demuxed mpeg2_ts audio shorter than video - help!
By LFNFan in forum Video ConversionReplies: 4Last Post: 7th Jun 2010, 09:14 -
Why is converted video shorter than original?
By mark86 in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 05:32
