I can import the DVR signal to my tuner card with this VLC command syntax:
v4l2-ctl -i 0ivtv-tune -c3But now I've switched the TV1 and TV2 outputs from the DVR, and I'm lost; anybody know which value I need to change for the signal to properly tune?vlc pvr:// :pvr-device="/dev/video0" :pvr-radio-device="/dev/radio0" :pvr-norm=0 :pvr-frequency=-1 :pvr-bitrate=-1
Solved; set command string 2 to channel <whatever DVR channel 2 is set to for modulator setup>. Default was 60, but it had been set to 73...
MEncoder outputs "could not find matching colorspace"
By codemaster in forum DVD RippingReplies: 0Last Post: 21st Sep 2011, 19:20 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th May 2010, 00:59 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40 -
Motorol 6412 DVR - how do I find channel status?
By z0diac in forum DVB / IPTVReplies: 9Last Post: 2nd Feb 2008, 00:00 -
help to set up a dvr and satellite signal input box, please
By The Muddler in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Jan 2008, 14:33
