Wld u guys recommend this monitor?
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&cs=19&sku=320-8846&bay...~ck=dellSearch
I dont think it has VGA connection but it had HDMI is that a better picture than VGA and am i ok with an ATI Radeon card unless you guys cld reocmmend anything better than ATI Radeon? Or is it only the screen that actually matters in regards to quality.
will i still get good quality with it running a 32 bit edition of windows?
Pls let me know if u htink its worth my while getting this.
I intend to play a little bit of gameso n it but mainly for movie watching.
Thank you.
If you don't need 3d why spend so much? I find the novelty of 3d wears off after a while and it just becomes annoying.
Hi mate,
aah ok so then just a basic monitor wld probably do me then eh? -
Depends what you want to use the monitor for, if you want it for colour correction then a video monitor is the way to go, if not then just go for a good quality LCD monitor, I agree with SE14 that 3D is a gimmick that will soon wear off, at least until it improves.
He's talking about using a calibrated monitor to adjust colors, brightness, and contrast in a professional photo/video editing setting. LCD monitor tend to have brightness problems near the edges of the screen and in dark/light extremes (crushed blacks and brights, inadequate black level, bluish blacks, etc.). On the other hand, LCDs are free of geometric and convergence distortions that plague CRTs.
Dualboot and LCD monitor Question?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 03:53 -
Question about using HDTV as Laptop Monitor
By Elemental Crisis in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2008, 05:42 -
Dual Monitor and TV Tuner question
By alanngray in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 15:22 -
LCD PC FP WS monitor question
By majax79 in forum ComputerReplies: 1Last Post: 15th Oct 2007, 10:15 -
LCD Monitor Question
By jollyjohn in forum ComputerReplies: 2Last Post: 21st Jul 2007, 06:39
