Ive tried to attach two audio tracks to a single video clip (part photo part video) by importing the edited divx format file and using the Movie Settings option to activate audio stream 1 and 2. Once you click on edit and properties of the clip I checked Multiaudio (for the two streams) and added the two mp3 audio tracks BUT IT PLAYS ONLY O N E !!! It is a 7 min clip and after the first song there is nothing just silence. It just doesnt play the second song. Also the fade in and out feature doesnt work - Ive tried it so many times maybe the sequence of how these functions are to be activated is wrong. I NEED HELP - Pls help and give me a step by step breakdown of how to get these features (Multiple Audio tracks on a clip and fade in and out of these tracks on the clip) to work. Also is it possible to set how long you want the song to play on your clip - i.e. supposing I only want half the song and then I want it to fade out and the next to fade in and start.
Thanxthanxthanxthanx
Lucie
Results 1 to 1 of 1
Machete 3.7 is released - edit video files with multiple audio streams
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 17th May 2011, 13:54 -
Multiple Audio Streams (Avi)
By nycboriqua in forum EditingReplies: 5Last Post: 26th Sep 2010, 17:42 -
Use to author from separate audio and video streams?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 05:41 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 12:54
