    Apr 2003
    Is it possible to untick the "Verify" and "Close Program" options that get turned on automatically when using ImgBurn DVD-Video Shell Ext v1.3 ?
    EDIT
    Manage to get the Verify option turned off within isoburn settings no luck with close program so far.
  2. It's called Check 'Close Program' in the settings.
    Apr 2003
    lol you dont say....
    I have that unticked in the options but when i use the shell extesion it is still checked
  4. There are a few of them (for each mode), make sure they're all unchecked.
    Beyond that, if the shell extension specifies the /CLOSE or /CLOSESUCCESS switch when it calls up ImgBurn, there's nothing you can do about it.
    The author of the shell extension will have to change their code to make it optional (by reading a registry value or whatever).
