Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD player? Does both mean the Blu-ray DVD can connect a TV to surf the internet or it can only watch movies from some specific websites such as Blockbuster, Netflix etc?
Results 1 to 10 of 10
Wifi ready and internet ready are two different things and your question is a two parter fyi.
It has to say "built in" wifi to be wifi ready out of the box. Otherwise you have to check the manual to make sure it can use a usb wifi adapter and which brand it accepts.
Otherwise the only thing "internet" ready means is it has a lan port (ie wired).
Yes it is only content specific, this isn't "webtv". They only go to the websites it supports natively. As far as I know there are no bluray players that have keyboard jacks and full web browsers and flash support.
For that you'd have to get Sony's newest "google tv" that they've been advertising. Though I seriously doubt that is a true "go anywhere" web browser in that tv - though probably the closest you'll get in an appliance without directly connecting a full fledged computer to your tv.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
And just because it connect to the internet, doesn't mean it can run all the "apps". You have to do some serious researching to find out what it can/can't do with its wireless connection and the internet.
Example: Samsung BD-C6900 can do Hulu Plus, but the BD-C6800 cannot. Even though both are "wifi enabled" out of the box, and both can run Samsung apps. (Note: They say that it should be able to run Hulu+ in the future.) -
Some of that stuff you have to take a firmware update, which is cool, then your device stays current.
Some manufacturers plan ahead, like Roku, and others put out a new model so it's a little scary out there on the bleeding edge. We don't even know who's gonna do what in the near future, maybe a lawsuit topples Google, who knows.
The HDMI connection has some kind of "Token Constraint System" that can be unleashed at any time, so I try to keep my component connections, if you're all HDMI you might get "down-rezzed" one day.
Check it out: http://en.wikipedia.org/wiki/Image_Constraint_Token -
[QUOTE=budwzr;2034780]
Check it out: http://en.wikipedia.org/wiki/Image_Constraint_Token[/QUOTE]
Can you say "macrovision"
Um...it's not Macrovision, that's old skool. HDMI is really a hardware communication protocol DRM scheme that hasn't been fully implemented yet. Most people think it's just an easy way to hook up audio/video, but it's a wolf in sheep's clothing. The ultimate trojan.
Right you are....but it's a heading in the copyright protection area that macrovision did. Now where's that little black box I used back in the "Old School" days....
Netflix feature on Blu-ray players
By Marco33 in forum Off topicReplies: 9Last Post: 25th Apr 2011, 10:41 -
How to use Wi-Fi feature in a Blu-ray DVD player to play a DVD movie or vid
By coody in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Sep 2010, 05:01 -
DLNA & Internet Ready LCD Help
By flicky in forum DVB / IPTVReplies: 0Last Post: 21st Apr 2010, 14:34 -
Name of feature that allows DVD/Blu-Ray players to remember spot when off
By Dreadnaught in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2010, 19:14 -
How to rip and stream DVD and Blu-Ray?
By mskvarenina in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Nov 2009, 07:56
