I have recorded various video with my mobile phone, transferred them to the laptop only to realise that the images are 'on their side' (rotated 90 degrees).
I can rotate the video by clicking on Tools-->Effects and Filters-->Rotate but I can't save the corrected video.
Can anyone help?
Results 1 to 9 of 9
Maybe you could tell us WHAT SOFTWARE you are using..........
View->Advanced Control. Click on the red record button. The file will be saved in your "my videos" folder.
Or it maybe just records the original stream. Try then Media Convert/Save.
Or rotate with Avidemux or virtualdub. -
You have to re-encode the file when you rotate the display,if you save as direct copy then it wouldn't re-encode.
How do I do a side by side video comparison in AvsP?
By Simcut in forum Newbie / General discussionsReplies: 15Last Post: 26th Mar 2012, 00:42 -
Is it Possible to Turn Off Internal HD to Save Power?
By imdaman in forum ComputerReplies: 7Last Post: 18th Sep 2010, 12:27 -
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 17:58 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 03:36 -
Vegas 6 Side by Side Video
By CobraStrike4 in forum EditingReplies: 1Last Post: 21st May 2008, 17:23
